Week of February 23, 2026 - Latest KB Articles and Known Issues
  • March 3, 2026
  • 29 views
A set of Knowledgebase Articles published last week is listed below. All KBAs can be searched via Global Search on the Support Portal and filtered by various components like product release.
KBA Title Portal Link and KBA Number Product Line
[MINOR] API created schedule has no end date Schedule Manager UI KB20016 Skylar One
Scheduled Backup Fails Due to Backup Deletion Error in Skylar Compliance KB19984 Skylar Compliance
Core Prerequisites for Establishing LLDP Relationships in Skylar One KB19885 Skylar One
[Minor] Leaderboard Bar Graph widgets data is not consistent with Dynamic app performance data (multiple metric series) (AP2) KB19775 Skylar One
[MINOR] Custom Attributes with single quotation marks not being populated from Dynamic App collection KB20026 Skylar One
What to Collect on "Optimization Assessment Service (OAS) Powerpacks" KB19945 Skylar One
How to Configure SNMPv3 on Cisco Devices for Skylar One Monitoring KB20034 Skylar One
[MINOR] Agent Upgrades via UI Can Not Download Installer for extended architecture KB20035 Skylar One
E-mail job 295596 failed: (530, b'Authentication required', 'SL1 Event Notifier x.x.x.x@example.com). KB19886 Skylar One
How-To: Safely Change the IP Address(es) for Skylar Automation Node(s) KB20009 Skylar Automation
How-To: Gather information on a failing GQL mutation KB19442 Skylar One
Is it Safe to Close Unused Docker Swarm Ports on a Single‑Node Skylar Automation (PowerFlow)? KB19864 Skylar Automation
When EKMS is disabled, changing Organization Visibility in AP2 UI causes the credential's password date to be corrupted. KB19798 Skylar One
Uptime is not showing in AIX Device KB19760 Skylar One
Best Practices for Setting Up RBAC in Skylar One KB20045 Skylar One
How to Configure the PagerDuty Integration with Multiple PagerDuty Teams KB20046 Skylar Automation
ScienceLogic Extended Technical Support KB20047 Skylar One
How to Check the Plugin Version Used by a Device in Skylar Compliance KB20033 Skylar Compliance
Amazon Web Services Discovery Failing with SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed errors KB20044 Skylar One
Gen 1 Agents are Not Collecting Data Due to HTTP 500 Errors Connecting to the Streamer on the Message Collector KB20059 Skylar One
Skylar One - Optimization Assessment Service (OAS) Healthcheck KB20060 Skylar One
