Week of March 16, 2026 - Latest KB Articles and Known Issues
  • March 25, 2026
  • 28 views
A set of Knowledgebase Articles published last week is listed below. All KBAs can be searched via Global Search on the Support Portal and filtered by various components like product release.
KBA Title
Portal Link and KBA Number
Product Line
[MINOR] Runtime Offset column can appear blank in Admin Processes UI
KB20394
Skylar One
 [NOTICE] Filesystem performance graph mouse hover can show mismatched unit values
KB20395
Skylar One
How to Send HTML Formatted Emails
KB20397
Skylar One
How to Edit a Form Field
KB20413
Skylar One
How to Format Collection Objects
KB20412
Skylar One
Best Practices for Generating Skylar One Events via the API
KB20416
Skylar One
How to Make Collected Software Data Visible
KB20415
Skylar One
[MINOR] Collection issues in Microsoft: SQL Server Enhanced Dynamic Applications when database instance names begin with the same name as another instance
KB20417
Skylar One
How to identify which plugin you need to backup a new device in Skylar Compliance
KB20349
Skylar Compliance
Skylar Automation Apps Fail Due to Incorrect Passwords After a Backup Restore
KB19957
Skylar Automation
Editing Skylar Automation configurations can cause Scheduled Apps to behave differently
KB19737
Skylar Automation
Updating MariaDB on Full STIG deployments
KB20025
Skylar One
The License Data Delivery Status dialog no longer updates in Skylar One 12.5.x
KB20191
Skylar One
How to fix high swap on collectors that have 32GB RAM or more
KB20192
Skylar One
[MINOR] Oracle Database v200 PowerPack getting AttributeError: 'NoneType' object has no attribute 'host'
KB20194
Skylar One
"Proc Mgr sanity check warning" Messages Seen When Adding a Collector to the System
KB20346
Skylar One
IP address is missing from the IP Address dropdown list on a device's properties page
KB20347
Skylar One
Skylar One Event "Illicit Service Running"
KB20359
Skylar One
What to collect on "Skylar AI: Anomaly Detection" incidents
KB20408
Skylar AI
[MINOR] AP2 may omit custom Dynamic Application columns that use index labels
KB20430
Skylar One
[MINOR] Availability charts may not display data gaps in 12.3.x
KB20431
Skylar One
[MINOR] False alerts from Support: Configuration File Validation when web-configurator password is set or changed
KB20432
Skylar One
How to Create an Organizational Form
KB20433
Skylar One
[MINOR] Interfaces page action menu can fail for non-admin users when filtering by organization
KB20434
Skylar One
[MINOR] Streamer Prime logs not rotating
KB20441
Skylar One
The Couchbase PowerPack does not allow use of %D in the URL field of credentials
KB20427
Skylar One
Preupgrade failing with "No mirrors left to try - All mirrors were already tried without success"
KB17971
Skylar One
[MAJOR] Critical Events "Skylar: Status Check Failed: Skylar Management -- SkylarConnectionError: error code: 401 . See /var/log/sl1/sl-otelcol-mgmt.log for details."
KB19645
Skylar AI
How to Enable One-Way CDP and LLDP relationships
KB20393
Skylar One
How to an Create an SNMP Device Class
KB20445
Skylar One
[MINOR] AP2 Classic Devices Collections expand/collapse does not work
KB20446
Skylar One
[MINOR] SNMP Walk Tool time display omits days when Show Type is unchecked
KB20447
Skylar One
[MINOR] AP2 config Dynamic Application data does not align correctly
KB20448
Skylar One
[MINOR] Web config utility changes to silo.conf do not persist
KB20449
Skylar One
Staging Upgrade Stuck in ‘Scheduled’ State
KB20419
Skylar One
[MAJOR] Skylar Automation - ServiceNow ticket creation failing with "failed to execute with exception: Execution Environment must be python3.6 or higher" after Skylar One upgrade to 12.5.x
KB19572
Skylar Automation
[MAJOR] Skylar Compliance sync pack upgrade issue in Skylar Automation v3.0.0
KB19582
Skylar Automation
Skylar Automation: SSO Authentication using Azure and DUO as a method
KB20394
Skylar Automation
Removing deprecated Execution Environments after upgrading to a 12.5.x version of Skylar One
KB20204
Skylar One
[Minor] Global Manager Managed Device Links Redirect to Child Stack IP Instead of FQDN
KB20469
Skylar One
[Minor] AP2 Dashboards Crash When Selecting Longer Time Ranges with Area Chart Stacking Enabled
KB20467
Skylar One
[NOTICE] OID Browser Symbolic Search Using Where Clause Does Not Return Results
KB20468
Skylar One
[NOTICE] An Unhandled Exception (UHE) Occurs in ScienceLogic Support PowerPack Due to Keyword FUNCTION
KB20466
Skylar One
Filter of Edit Date column in Inbound Email page is not working
KB20472
Skylar One
Outbound Mail Sent to AWS SES Requires Separate Credentials for Each Region
KB20473
Skylar One
[MAJOR] Ticket Notes Cutoff and Double-Click Functionality in Skylar One v12.5.x
KB20279
Skylar One
How to Create Custom Links
KB20396
Skylar One
What is the difference between PowerShell credential test and the actual PowerShell Dynamic Application collection?
KB20444
Skylar One
