Week of March 22, 2026 - Latest KB Articles and Known Issues
  • April 7, 2026
  • 16 views
A set of Knowledgebase Articles published last week is listed below. All KBAs can be searched via Global Search on the Support Portal and filtered by various components like product release.
KBA Title Portal Link and KBA Number Product Line
How to Search Devices with GQL
Skylar One
[MINOR] NSX-T Logical Switch Performance Dynamic Application Fails To Collect Data
Skylar One
[NOTICE] Universal Credential template reverts after platform upgrade and is restored by reinstalling associated PowerPack
Skylar One
[NOTICE] Modify by Template on Registry > Devices may close without saving changes
Skylar One
[MINOR] False device failed availability alerts for Gen1 Agents.
Skylar One
How to Search Events with GQL
Skylar One
Best Practices for Interface Monitoring in Skylar One
Skylar One
Applying Device Templates Automatically
Skylar One
Collector / Partition Full Caused by Large db2diag.log Log File
Skylar One
[Minor] DR backup failing with an unhandled exception error
Skylar One
Vulnerability scan reports outdated kernel versions even though the appliance has been updated.
Skylar One
L3 Relationship Not Forming when topology disocvery from UDP-based traceroute
Skylar One
Is there any out of the box (OOTB) report for Device component mapping?
Skylar One
Unable to delete credential
Skylar One
Asset Manager not saving Administrator and Technician Values
Skylar One
PowerPack build fails with error "Class 'ppack_' not found"
Skylar One
Bulk device deletion dialog incorrectly reports deletion failures, although the devices are successfully deleted.
Skylar One
The /etc/dnsmasq-resolv.conf file does not exist on a newly installed appliance.
Skylar One
[Notice] Dynamic application "NetApp: Disk Config C-Mode" fails to fetch disk information
Skylar One
Maintenance schedule is off by one hour
Skylar One
Is HA Proxy supported for a Phonehome Collector connection?
 Skylar One
[MINOR] VMware: "NoneType" exception in VMware: Datastore Cluster Configuration application
Skylar One
[MINOR] Dashboards Using Device Group Widgets May Show Incorrect Count
Skylar One
Cisco Meraki device status alerts appear late in Skylar One
Skylar One
What happens to pending application runs when RabbitMQ queues are purged?
Skylar One
High Bandwidth Utilization Alerts on Logical Interfaces
Skylar One
[MINOR] Search box is displayed under Create New button from Unguided device discovery and is not required.
Skylar One
[Minor] 'Update Device State' process can end in a SIGTERM under certain conditions.
Skylar One
Reporting on Specific Hours of the Day in ScienceLogic (Skylar One) for all Reports.
Skylar One
Cannot Delete a Credential. It is Aligned to a Dynamic Application or Device
Skylar One
AttributeError: 'dict' object has no attribute 'iteritems' for Pure Storage FlashArray Powerpack V103 collections
Skylar One
Skylar Automation sync CI attributes from ServiceNow fails with 500 error.
Skylar Automation
Skylar One Windows Remote Management Configuration Tester
Skylar One
Why I receive "The term 'Invoke-SqlCmd' is not recognized as the name of a cmdlet" error when trying to discover and monitor Microsoft SQL Server?
Skylar One
