Week of March 9, 2026 - Latest KB Articles and Known Issues
  • March 18, 2026
  • 21 views
A set of Knowledgebase Articles published last week is listed below. All KBAs can be searched via Global Search on the Support Portal and filtered by various components like product release.
KBA Title Portal Link and KBA Number Product Line
How to Reuse a Variable in a Device Template in Skylar Compliance KB20376 Skylar Compliance
[NOTICE] Collection Poll Frequency override icon overlaps text in AP2 Collections KB20298 Skylar One
Windows PowerShell collections fail due to ERROR: Connect error WinRMTransportError: Bad HTTP response returned from server. Code 400 KB20311 Skylar One
Windows PowerShell collections fail due to ERROR: Error WinRMTransportError trying to connect to server: Bad HTTP response returned from the server. Code: 500, Content: '' KB20312 Skylar One
How to Create an Organizational Event Policy KB20313 Skylar One
[MAJOR] Ticket editor notes may be truncated and ticket row double-click may not open details KB20314 Skylar One
[MAJOR] AP2 dashboard widgets may show no data for "Last..." time ranges with hourly or daily rollups KB20315 Skylar One
[MAJOR] Interface sync from SL1 to ServiceNow fails on GQL interface query KB20316 Skylar One
[MINOR] GraphQL highAvailabilityStatus may report false for active DB node in HA deployments KB20317 Skylar One
[NOTICE] Audit log may omit user value for "Device Unaligned and Data Successfully Removed for Device" KB20318 Skylar One
Non-SNMP IP Range Discovery Fails for ICMP Blocked Devices KB20319 Skylar One
[MINOR] Business Service health and related performance widgets may fail due to invalid presentation label references KB20320 Skylar One
[MAJOR] Classic dashboard custom tables may fail to show filtered device group results KB20327 Skylar One
Silo API import needs new path when moving from py2 to py3; otherwise get error: ModuleNotFoundError: No module named 'silo_api_support' KB17111 Skylar One
[MINOR] Run Book Actions in the Amazon Web Services PowerPack discovery process may fail due to SSL verification credential settings KB20330 Skylar One
[MINOR] Heat map option may not persist after saving Interface table widgets KB20331 Skylar One
[MINOR] Dynamic Application SNMP object-collection types and indexes missing KB20332 Skylar One
[NOTICE] Ticket list double-click may fail to open ticket details KB20333 Skylar One
[MAJOR] Dashboard-level device group filtering may exclude devices when state records are missing KB20334 Skylar One
[MINOR] Report Format Conversion Failed with error "Existing listener not found" KB20335 Skylar One
[MINOR] Device Investigator custom panel index not retained KB20336 Skylar One
[MINOR] Dashboard widgets may fail when filtering interfaces by multiple tags KB20337 Skylar One
When using ServiceNow Base Pack v108, "Python Assessment Tool" reports that some Dynamic Applications and Run Book Automations still use Python v2 instead of Python v3 KB20225 Skylar One
[MINOR] AIX classification is not occurring KB20308 Skylar One
[NOTICE] Device Processes Registry Cannot Be Loaded in User Interface When Millions of Processes Collected KB20350 Skylar One
Deployment Automation PowerPack- SSH Connection FAILED KB20351 Skylar One
[MAJOR] Unhandled exception during collection "old_div return a / b ZeroDivisionError:float division by zero", process "Data Collection: Interface Bandwidth" KB20179 Skylar One
Command Length Exceeded for WinRM Powershell Collections KB19573 Skylar One
Monitored Windows Service is running but shows Availability of 0 KB20289 Skylar One
How to change the Collection State of a device in User-Initiated Maintenance to Active in the New (AP2) UI KB20288 Skylar One
NSX‑T Interfaces Not Collected by VMware: NSX‑T ICDA Dynamic Applications (SSL Verification) KB20360 Skylar One
HPE: Edge Connect Orchestrator Performance Dynamic Application: No data collected for disk and memory metrics from cloud Orchestrator instances KB20361 Skylar One
How to Forward Audit Logs to External Systems KB20362 Skylar One
How to Use the News Feed Manager KB20363 Skylar One
How to Create Device Class Using Nmap KB20364 Skylar One
How to Configure External RSS Feed Events for Skylar One Automation Policies KB20365 Skylar One
How to Add Locations for Geographic Maps KB20366 Skylar One
How to Query and Delete Custom Links KB20367 Skylar One
[NOTICE] Admin Notifier shows stale system warning count after events clear KB20368 Skylar One
How to Create a Geographic Map KB20375 Skylar One
[Minor] Stack version not showing in Global Manager when stack got discovered using VIP KB19985 Skylar One
Does our SL1 Central Database (CDB) appliances have to be time synchronized? KB20253 Skylar One
Remove Devices in Bulk Using GraphQL KB19906 Skylar One
All the MQ subcomponents have been vanished, and discovery logs indicate "No Data" KB19928 Skylar One
Enabling Skylar Analytics (metadata exporter) in Skylar One can result in datapull memory exhaustion and data not appearing in Skylar Analytics. KB20286 Skylar One
[MINOR] Event Timestamp and Collection Timestamp show the future on agent device KB20378 Skylar One
[MAJOR] Ad Hoc Report fails when converting to non-ODS format after reboot of the DB/AP KB19854 Skylar One
