We are pleased to announce that the HPE Edge Connect v200 Py3 PowerPack has been released. The download for this release can be found on the Support Portal under the PowerPack filename:
https://support.sciencelogic.com/s/release-version/aBu0z000000XZaHCAW/hpe-edge-connect-silver-peak
Enhancements and Issues Addressed:
- Updated the PowerPack to be compatible with Python 3
- Converted all Dynamic Applications to Python 3.
- Added two new Dynamic Applications to the PowerPack:
- HPE: Edge Connect Appliance Memory Performance
- HPE: Edge Connect Appliance CPU Performance
NOTE: Both of the "HPE: Edge Connect Appliance Memory Performance" and "HPE: Edge Connect Appliance CPU Performance" Dynamic Applications are disabled by default. Enabling the "HPE: Edge Connect Appliance CPU Performance" Dynamic Application may cause performance issues on the orchestrator due to the Dynamic Application calling the API for each appliance device.
- Removed the "REST: Performance Monitor" Dynamic Application from the PowerPack, as it is not compatible with the Snippet Framework.
IMPORTANT: Before upgrading to version 200 of the PowerPack, ScienceLogic recommends unaligning the "REST: Performance Monitor" Dynamic Application from existing root virtual devices.
- Added the new "HPE: Edge Connect v200 API Key" UCF subtype to the PowerPack.
- Added the new "HPE: Edge Connect API Key Example (UCF)" example credential to the PowerPack.
- Added a function to the snippet of each Dynamic Application in the PowerPack that checks for an API token in the headers. If one is found, you will receive a warning that instructs you to move the token to the "Embedded Password [%P]" field.
NOTE: ScienceLogic does not recommend storing tokens in plain text fields, as this goes against security best practices.
Please refer to the HPE Edge Connect v200 Py3 PowerPack File Details in the PowerPacks section of the Support Portal for all information pertaining to the HPE Edge Connect v200 Py3 PowerPack Support Status, Minimum SL1 Version, Solution Information, and Pricing Information. The HPE Edge Connect v200 Py3 PowerPack Release File Details also contains links to the Release Notes, Manual, and PowerPack Info Report.
Issues Addressed in the HPE Edge Connect v200 Py3 PowerPack Release can be found in the Release Notes.
