Low-code Tools v103 PowerPack Release Notification
  • May 7, 2025 4:59 PM UTC
  • 7 views
We are pleased to announce that the Low-code Tools v103 PowerPack has been released. The download for this release can be found on the Support Portal under the PowerPack filename:
https://support.sciencelogic.com/s/release-version/aBuVL0000000ACH0A2/lowcode-tools
Enhancements and Issues Addressed
The following enhancements and addressed issues are included in this release of the PowerPack:
  • You can now select Python 3.6 from the Environment Type drop-down field when creating execution environments.
  • Credential names are now consistent between both standard and custom function substitutions, which allows you to request credential fields when writing snippet arguments.
  • When defining a SOAP/XML credential with cURL commands, SL1 will use the basic authentication method if the value populated in the %1 field is not a registered method of authentication.
  • Resolved an issue where token requests did not utilize your proxy configurations, subsequently causing failed requests or connectivity issues. SL1 now uses your proxy definitions when generating tokens via snippet arguments and credentials.
  • Resolved runtime errors when using version 102 of the "Low-code Tools" PowerPack on OL7 systems.
  • Resolved an error that occurred when using built-in substitutions without a value set.
  • Resolved an issue where users authenticated through OAuth2 were unable to change their custom HTTP headers.
  • The "Low-code Tools: Rest" credential in this PowerPack can now perform "%D" and "%N" substitutions for the following fields:
    • URL
    • Token Retrieval Endpoint
NOTE: The credential version number will no longer be identical to the version number of this PowerPack.
TIP: Full documentation for the "Low-code Tools" PowerPack is provided at the following location: https://docs.sciencelogic.com/dev-docs/low_code_tools_v101/index.html
Please refer to the Low-code Tools v103 PowerPack File Details in the PowerPacks section of the Support Portal for all information pertaining to the Low-code Tools v103 PowerPack Support Status, Minimum SL1 Version, Solution Information, and Pricing Information. The Low-code Tools v103 PowerPack Release File Details also contains links to the Release Notes, Manual, and PowerPack Info Report.
Issues Addressed in the Low-code Tools v103 PowerPack Release can be found in the Release Notes
