Low-Code Tools v104 PowerPack Release Notification
  • September 19, 2025
  • 1 view
We are pleased to announce that the Low-code Tools v104 PowerPack has been released. The download for this release can be found on the Support Portal under the PowerPack filename:
https://support.sciencelogic.com/s/release-version/aBuVL0000000ACH0A2/lowcode-tools
Enhancements and Issues Addressed
The following enhancements and addressed issues are included in this release of the PowerPack:
  • When creating token-based authenticators, you can now customize the behavior of each authenticator so that it meets specific use cases. The token, APIToken, and OAuth authentication methods can now inherit a new base helper class to allow high configurability for each authenticator.
  • When sending outbound HTTP requests, you can now see what is being sent so you can debug issues as authentication problems and incorrect headers. All outbound requests now include the following details:
    • Request URL
    • Request method
    • Headers
    • Body (if applicable)
  • Addressed an issue where empty HTTP headers triggered invalid header messages.
  • Addressed an issue in the authentication module where logging certain objects could cause errors.
  • Addressed an issue where invalid request IDs caused an unhandled exception.
  • Corrected parsing so that Unicode characters are now recognized and displayed properly.
  • Added the "Low-code Tools: rest v104" credential, which addressed an issue where API keys were not hidden in previous versions.
  • You can now create dynamic and reusable execution plans for Snippet Arguments using a Macro Syntax.
  • Addressed an issue where JMX requests would not honor the timeout specified in credentials.
NOTE: The credential version number will no longer be identical to the version number of this PowerPack.
TIP: Full documentation for the "Low-Code Tools" PowerPack is provided at the following location:  https://docs.sciencelogic.com/dev-docs/low_code_tools_v104/index.html
Please refer to the Low-code Tools v104 PowerPack File Details in the PowerPacks section of the Support Portal for all information pertaining to the Low-code Tools v104 PowerPack Support Status, Minimum SL1 Version, Solution Information, and Pricing Information. The Low-code Tools v104 PowerPack Release File Details also contains links to the Release Notes, Manual, and PowerPack Info Report.
Issues Addressed in the Low-code Tools v104 PowerPack Release can be found in the Release Notes
