We are pleased to announce the release of Power pack ScienceLogic: Skylar Automation Monitoring v109.
https://sciencelogic.lightning.force.com/lightning/r/Release_File__c/aBtVL0000001oPN0AY/view
Skylar Automation Monitoring PowerPack 109 addresses the following issue:
The "Skylar Automation Queue Configuration" Dynamic Application no longer raises repeated events for a task that has already failed. In version 108, the application asked Flower for failed tasks from the last 1200 minutes (about 20 hours) but had no way of recognizing tasks it had already reported. Every 15-minute poll raised a new event for each failed task still inside that window, so a single failure kept re-alerting for up to 20 hours.
Affected version: Skylar Automation Monitoring PowerPack 108.
Resolution: Upgrade to PowerPack version 109. You should now get one event per failed task.
Workaround for version 108: In the "Skylar Automation Queue Configuration" Dynamic Application, change the time window from 1200 minutes back to 15 minutes, to match the poll frequency.
