Solved
Any way to "ignore ssl" in a web content monitor?
  • May 16, 2025 8:19 PM UTC
  • 2 replies
  • 30 views
Jeff_Kinny
Hi All,
We're trying to do a quick and dirty web content monitor, very simple, just hit a target website and if you see a 200 it is a 'success'. I created the web content monitor and when SL1 hits the endpoint in the UI we get a timeout error.
To make sur eit wasn't something else we ran a "curl -k https://website" from the collector and it worked, however ssl failure without the -k.
It doesn't appear that there is an option to turn off ssl verification in the web content screen, but please let me know if I'm mistaken?
Best answer by TonyAndres
Hello Jeff,
When using curl, the -k parameter is the same as --insecure. Using the -k parameter is what skips the SSL verification step and is what you should be using.
In the web content monitor itself, you can set SSL Encryption to Disabled to remove this step as well.
Antonio Andres
View original
TonyAndres
  • Community Manager
  • Answer
  • May 19, 2025 11:42 AM UTC
Hello Jeff,
Antonio Andres
Jeff_Kinny
  • Author
  • Contributor II
  • May 19, 2025 5:08 PM UTC
Nevermind my second question, the URL we were using was incorrect!
