As-built script for ScienceLogic configuration
  • Apr 8, 2025 5:37 AM UTC
  • 2 replies
  • 22 views
Hi,  dose anyone know of a script that you run, to detail your ScienceLogic application's configuration, so that you can write a ScienceLogic "as-built" application document?   Not interested in the underlying servers for this particular ask, as my use case is a ScienceLogic SaaS instance.
Thanks! Anne
Issac
Forum|alt.badge.img+1
  • Contributor III
  • Apr 8, 2025 4:17 PM UTC
Hi ,
What kindly of configuration are you looking ,its system setting ? Can you share some examples
TonyAndres
  • Community Manager
  • Apr 18, 2025 11:47 AM UTC
Hello Anne,
You can back up all of this information you are asking about with the Config Backup. The Config Backup will store all of the configuration settings in SL1 and also backup all of the required configuration files from the CDB. We recommend taking a daily Config Backup, as these normally run much quicker than Full Backups. Other than this, we do not have an OOTB script that will back up this information outside of SL1.
Antonio Andres
