Credentials are not inherited to Component device
  • Jul 31, 2025 3:07 PM UTC
  • 1 reply
  • 7 views
Issac
Forum|alt.badge.img+1
Hi All,
 We are trying to change the credentials for a onboarded meraki organization ,but if we change it to root device that is not inherited to child components. The updates are not pushed.
We can control via device template for this update , but its a time consuming process and its should be work in this way.
1 reply
TaylorJohnson
  • Community Manager
  • Jul 31, 2025 3:46 PM UTC
Hello Isaac,
If you'd like to request a change to how credentials are managed and aligned in SL1, I suggest creating (or voting an existing) idea in Ideas Hub. Adding some additional details like other use cases and what you'd like the user experience/workflow to look like will be helpful when you do.
Edit: I see you have a similar idea submission waiting to be published by our product team. That will be a good place to discuss when it's published.
Thanks,
Taylor
