Dashboarding: questions and (maybe) ideas
  • Jun 25, 2025 12:32 PM UTC
  • 2 replies
  • 34 views
teppotahkapaa
Forum|alt.badge.img+1
Sorry because I am the major wrong-doer, I put quite many things in this post.
  1. Table widgets. What is the meaning of Aggergation in Metrics value. For me it seems whatever I choose from there the values are always the same, in
    this example above table widget shown Max and lower Min aggregations, and those values are not dependent of chosen time window, seems to be the last value, always.
  2. the Aggregation in table widgets. As I as a human (would like to) understand should show the Max and Min values of the metrics from the chosen time window. Am I just understanding it wrong?
  3. Index names in table widgets. In graph it shows those index names but I have not been able to show those names in table, just values. Is that Works-as-Designed or my mistake?
  4. Help in editing dashboards? In AP2 UI all help seems to be behind Help button in the title row. Except that in some windows, for example when you are editing dashboard widgets, there is no title row -> no help available. For user that means that I have to close editing that widget, go back, press help and then go back to dashboard page/tab and start editing that widget. Not very user friendly. Is that also Works-as-Designed?
These are from 12.3.5 + 8.20.2
teppotahkapaa
Correcting one issue, about index names, with Leaderboard Bar Chart one can show indices only. Which is actually logical, so point 3 is "solved"
  • Community Manager
  • Jul 31, 2025 9:52 PM UTC
Regarding #1 and #2.
Table widgets will always show the last collected value for the selected time range. If the metric Rollup Frequency is configured for "Auto" and the time context of the dashboard is < 3 days, or statically configured to "Raw", then this metric value will be the collected value for the last poll; the Aggregation setting does not factor as there is no average, min, or max for a single collected value.
If the metric Rollup Frequency is configured for "Hourly" or "Daily", or "Auto" and the time context of the dashboard is > 3 days, then the value presented for the metric within will be the selected Aggregation for the last respective rollup calculated within the selected dashboard time context.
The ask of presenting a single-value (a la table, gauge, bar, etc..) that represents the max, min, or average over the dashboard time context is only available through the Leaderboard visualization. In the case of the Leaderboard visualizations:
Leaderboard’s displayed values are the metric’s average over the selected timespan by default. Each selected metric may be have a respective aggregation (Avg, Min, Max) as well as set to have the data point determined from either 1) Full Dashboard Timespan 2) Last Poll in the Timespan 3) Off - Not factored in Top-N calculation and displays last poll
Regarding #4, as far as I'm aware neither the newer Help Drawer nor the page header bar have ever been presented within the dashboard widget edit experience, however, that doesn't mean that's the best experience. Do you have particular examples as to what information you'd like to see made available through the widget editor experience? Effectively the Help Drawer for dashboard's predominantly links to the online documentation and doesn't provide in-depth information within the Help Drawer itself, but understanding your pain points and the type of information driving you to the Help Drawer would be excellent context if you'd be kind enough to share.
