Question
FileSystem unavailable Critical\major Events are Creating Noise
  • Jul 2, 2026 6:53 AM UTC
  • 4 replies
  • 119 views
ask_baljeet.3
We have been dealing with unknown behavior in our ScienceLogic Environment, and we would like to explain point wise to keep it clean.
  • Application Team has reported us that File system Unavailable events are landing in their SNOW queue in the form of ticket.
  • We have investigated and File System unavailable major events have been triggered. Furthermore, we have navigated into Registry » Hardware » searched with specific server name to find out reported File System have been discovered or not.
  • We have found that those are not discovered and when connected back to the application team. we have got two types of inputs.
  • 1st » multiple File System unavailable event are trigger for user profile for example /home/baljeets [whenever user log into Solaris Server. there profile will be created and once they logoff from the server FS related to their profile will be unmounted and ScienceLogic triggers major]
  • 2nd » backup job will be triggering time to time and once the backup job is complete. same kind of file system unavailable major event will be triggered
TonyAndres
  • Community Manager
  • Jul 6, 2026 12:31 PM UTC
Hello Baljeet,
What is the Type for these filesystems in the Devices > Hardware page? Do you have a screenshot of an example event?
Antonio Andres
ask_baljeet.3
  • Author
  • New Contributor
  • Jul 6, 2026 12:42 PM UTC
Hello Tony
This problem is, whenever, we are checking in hardware page for File System discovery. We are not seeing any object discovery details. This is the problem.
had it been there, then we would have disabled it and this could have resolved our issue.
TonyAndres
  • Community Manager
  • Jul 6, 2026 12:43 PM UTC
Hello Baljeet,
Antonio Andres
I think we had something similar with /dev/loop folders. These are filesystems which are temporarily mounted. As soon as they disappear they will create events. I think problem is Skylar One does not use UUID to identify storage partition.
We modified event policy regex to exclude and suppress.
Kind regards,
Dennis van Amerongen
