Please anyone can help with DB2 HADR credentials - how to ?
  • May 30, 2025 6:21 PM UTC
  • 5 replies
  • 17 views
Please as there is no documentation does anyone successfully use DB2 HADR powerpack ?
For interconnection, do I need ssh + db2 credentials combination ? Should I define some DB2 credential and then mapped to SSH credential within new Soap credential ? how to map ? Or do I need only Soap with mapped ssh id header ?
Thank you very much.
  • Contributor III
  • May 30, 2025 7:06 PM UTC
Are you referring to the "Community" PowerPack "IBM Db2 HADR" ?
https://support.sciencelogic.com/s/release-version/aBu0z000000XZOpCAO/ibm-db2-hadr?tabset-89da3=2
I am not able to find any more information about this Community Powerpack.
  • Contributor III
  • May 30, 2025 8:01 PM UTC
@but7villa_kd The November 2024 update was the fix for encryption, but it wasnt a regular release/update. This PowerPack was initially uploaded in April 2018.
but7villa_kd
Forum|alt.badge.img+1
  • Contributor II
  • Jun 2, 2025 1:14 PM UTC
@DipakShah Has IBM DB HADR monitoring been considered for inclusion in the IBM DB2 PP or as a standalone PP ?
Is there enough community support for such an effort ?
but7villa_kd
  • Contributor II
  • Jun 2, 2025 6:51 PM UTC
@DipakShah can we tie this together with this Idea from 7 months ago, where SOL-4258 was filed?
https://community.sciencelogic.com/idea/powerpacks-ideas/ibm-db2-power-pack-unable-to-detect-hadr-status-which-is-active-and-standby/2060
  • Contributor III
  • Jun 3, 2025 2:40 PM UTC
Martin, Yes, I know about that feature request and also about this Community PP.
When we start work on the DB2 PP to support HA, we know that we will evaluate this solution to understand if we can replicate that. As you have experienced trying to use the PowerPack, we will not solely depend on what this PowerPack is doing, but rather design a solution that we can test and validate.
