How to Scale Expertise and Level-Up Engineers with Skylar Advisor
  • Jun 16, 2026 7:16 PM UTC
  • 42 views
SaraLeslieAdmin
In this video, see how Skylar Advisor helps L1 and L2 engineers work more efficiently by providing real time guidance, context, and next step recommendations throughout the troubleshooting process.
From understanding unfamiliar terms to documenting resolutions, Skylar Advisor turns complex systems into intuitive, guided experiences.
Explore how Skylar Advisor enables:
• Instant context for unfamiliar terms, devices, and concepts
• Guided prompts to support next best actions during investigations
• Built in note taking and documentation through scratch pads
• One click capture of resolutions to build organizational knowledge
• Continuous learning through shared insights and reusable knowledge With Skylar Advisor, every operator can work with greater confidence, reduce time to resolution, and continuously build expertise across the team.
Learn more about the ScienceLogic AI Platform: https://bit.ly/4a4gIaD
