Issac
Expert
5 months agoDashboard filter using output
There is any possibility to create a AP2 dashboard to display the devices which are greater than 50% of avg cpu ? Anyone have tried sorting with output value is also not possible.
I think what your thinking is you want to display the data in a device table, showing devices great than 50% CPU utilization. From what I can see in a device table you can sort by device name and IP, but you can't sort using CPU utilization or any of the vital metrics. exclusion rules don't look like they are available either.
Yes , that correct the sorting will not work , that really a basic thing which is missing
