Forum Discussion
Pritam's avatar
Pritam
Icon for Contributor II rankContributor II
12 months ago
Solved
Hung State
“If the server is in a hung state, is there any way we can trigger an event?”
  • TonyAndres's avatar
    12 months ago
    Hello Pritam,
    If SL1 is completely hung, meaning the em7 service is no longer functioning, then SL1 will also be unable to report that the service itself is no longer working, as the service running is required for events to occur. You would need to set up monitoring of the SL1 appliances using a different SL1 stack.
    Regards,
    Antonio Andres
