Forum Discussion
mattwestjames's avatar
mattwestjames
Icon for Contributor II rankContributor II
10 months ago
Solved
Low Code Step: store_data
Does anyone have an example of using the low code step: store_data?  I have no problems storing the data, but trying to pass it to the next html step with the data being the URI.  low_code: id: ...
  • MattH's avatar
    MattH
    10 months ago
    I just re-read your question. You are looking to get a result and then use that in another http step right?
    We call that dependent collections. It is documented here. It should still apply to Low-code Tools v102. However, if you still want to use store_data there is an example here.
