Forum Discussion
TaylorJohnson's avatar
TaylorJohnson
1 year ago
Solved
Possible deprecation of legacy HPE Edge Connect authentication
Hello all!  We are working on an update to the HPE Edge Connect PowerPack that converts the dynamic applications to use the snippet framework. This will improve supportability, simplify troubleshoo...
  • TaylorJohnson's avatar
    11 months ago
    v200 of the HPE Edge Connect PowerPack will be dropping the legacy "cookie auth" support. Please switch to API key auth prior to upgrade.
