Forum Discussion
SunnyPawar1989's avatar
SunnyPawar1989
Icon for Participant rankParticipant
1 year ago
Solved
To monitor NFS volume usage
Hi  Can we monitor NFS file/volume usage in SL1, if so which powerpack we can use. Kindly suggest. Regards,
  • TonyAndres's avatar
    1 year ago
    Hello Sunny,
    Assuming you are leveraging the Data Collection: Host Filesystem Inventory process, which is our internal filesystem collection process, you can navigate to the System > Settings > Behavior page and uncheck the option NFS Detection Disable. This will allow the NFS drives to be discovered by SL1.
    If you are using a specific, non-ICDA dynamic app to discover the filesystems, then we will need to know which dynamic app you are using to see if NFS drives can be discovered and monitored via that specific PowerPack.
    Antonio Andres
