Jeff_Kinny
Contributor III
7 months agoAny way to "ignore ssl" in a web content monitor?
Hi All, We're trying to do a quick and dirty web content monitor, very simple, just hit a target website and if you see a 200 it is a 'success'. I created the web content monitor and when SL1 hits t...
- 7 months ago
Hello Jeff,
When using curl, the -k parameter is the same as --insecure. Using the -k parameter is what skips the SSL verification step and is what you should be using.
In the web content monitor itself, you can set SSL Encryption to Disabled to remove this step as well.
Antonio Andres
