Forum Discussion
Hi ,
What kindly of configuration are you looking ,its system setting ? Can you share some examples
Hi Issac, We are looking for the ScienceLogic application configuration settings - the type of settings that you'd need to put in, if the system needed to be recovered completely from scratch, taking the worst possible case that backups were completely unavailable. So global settings, details of the collectors, what templates we are using and the template settings, account profiles and role settings, what powerpacks we are using are where they are aligned, organisation names, devices we have onboarded, (the ones using agents, vs no agents). I was hoping for something that a script could produce, rather than doing many screenshots. Thanks for your reply to me, I do appreciate it.
- Issac8 months ago
Expert
As of now i don't think SL has those kind of OOB scripts , may be use rest api or SQL query to grap those information daily or weekly basis .
Apart from this SL has a good module called powerpack which helps to add all your device groups, templates, dashboards, Run books ,devices classes etc, You can create your own pack can add the core things and export
