Forum Discussion
TaylorJohnson's avatar
TaylorJohnson
5 months ago
Solved
Possible deprecation of legacy HPE Edge Connect authentication
Hello all!
We are working on an update to the HPE Edge Connect PowerPack that converts the dynamic applications to use the snippet framework. This will improve supportability, simplify troubleshooting, improve performance, and make it easier to customize the collections to suit your needs.
As part of this, we are considering dropping support for "cookie" auth and requiring users to use API keys to connect SL1 to the Edge Connect Orchestrator.
If you have a use case that precludes using an API key for this integration, please reach out and help us understand your parameters.
Thanks!
  • v200 of the HPE Edge Connect PowerPack will be dropping the legacy "cookie auth" support. Please switch to API key auth prior to upgrade.
1 Reply
