MarkC
2 months agoContributor II
IPv6 only monitoring issues
Hi,
Has anyone developed a custom monitoring solution for IPv6 only devices?
I am looking for PowerShell, Linux Powerpacks and a credential tester.
Currently the SL1 solution does not support this scenario for Windows Servers. I believe the same issue exists for Linux devices using the host resource power pack, but I do not have a ipv6 only Linux server to test this scenario.
Both situations should fail to provide a port list as it requires Nmap -6 which is not supported in the solution. I am not sure if the issue would fail on web checks, ssl certs, and other components in the system.
Any help or experiences you have would be helpful as we navigate this issue.
